Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Phone will not turn on
I have tried holding power and the home button does not turn on. I took it into the apple store and they said the phone isnt receiving a charge at all and a replacement is $300.
I tried disconnecting the battery and turning it on while plugged in and nothing.
The phone was just laying on my night stand plugged in and decided not to work the next day.
The phone has never had anything replaced.
Is it the logic board that needs to be replaced?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
Charging IC chip could be at fault. Have you tried a iPhone 6 battery that has some charge in it to check if if the phone still turns on? Don't need to replace the logic board just yet.
von
Also be sure to inspect the dock flex as well. If I recall correctly, the Geniuses at Apple use a USB multimeter and if it's reading 0.00 amps, then the dock may be at fault as well. Let us know how it goes!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Most common issues for a "out of the blue" dead iPhone 6 are that the tristar charging ic has failed--in the 6 this chip is required for the phone to boot. This chip gets damaged from use of non-Apple chargers/cords.
The second most common issue is a full short on the VCC_MAIN line on the board which can happen from a failed cap.
Both can be repaired but require specialty microsoldering equipment and troubleshooting. Most people send the board out for these kinds of repairs.
War diese Antwort hilfreich?
Bewertung 2
thanks for all the help. looks like I will have to send it out. Any recommendations?
Bewertung 0
Antwort hinzufügen
Tony Tam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 186
