Changing the front screen
Does the ipad mini 2 with wifi and with the without the wifi, both have magnet's on them and while repairing what are the difference's that we have to be careful with?
Ist dies eine gute Frage?
As Ben said - originally all of them have a magnet. When you are replacing the screen with digitizer you will find the hardest thing LCD screen removal - connection cables are under it and this bloody thing is glued quite firmly on the thermal shield. It is really a pain if you are not careful - use heat, a lot of patience and recommended method is with a dental floss.
And - be careful - in 99% you will have to replace magnets from old glass to new glass - don't be cheap and buy some cheap plastic - go for OEM and you will be out of trouble.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 71
1 Kommentar
All iPads come with Wi-Fi. You mean without the sim card data capability (3G / 4G).
Yes, every iPad that can use a iPad cover to lock the iPad automatically when closing the cover has a magnet on it. Both iPad Mini 2's will have magnets on them. I haven't repaired one myself but there will most likely be more adhesive when it has a 3G / 4G antenna module in it. Usually at the top of the screen.
von Ben
