Zum Hauptinhalt wechseln
Repair guides for the variations of the Compaq Presario CQ62 laptop. This brand was manufactured from 1993 to 2013, and was owned by HP from 2002 to 2013.
51 Fragen Alle anzeigen
It won't power up with the power plug in, battery died.
I always use my Compaq Presario with the power cord plugged in, never take it anywhere. Tonight it said the battery was low, and a few minutes later it shut off. I turned it back on and white text on a black screen said to charge the battery or plug in the power cord. The power cord was already plugged in; I clicked to continue. It started up for 10 -20 seconds then powered off again. The power cord it putting out approx. 19 volts, but it won't start again. I unplugged & plugged it in again, the light blinked blue a few times then stopped.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Take out the laptop battery then plug it in. See if it turns on fine. If it still does then you will need to replace the battery if you want to run the laptop on battery power. By the way it's okay to run a laptop without a battery as long as you don't move the charger cord or the laptop (unplugging it will make the laptop shut off because no power)
If you want to buy the battery search 'Compaq Presario CQ62 battery' on eBay. You can make sure it's the correct battery by searching via the battery's model number instead. The laptop model number is usually good enough in most cases.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
My CQ61 doesn’t turn on even with the power cord in and the battery out. When I push the power button the lightning bolt light near the left side of the mouse pad just blinks 3-4 times but nothing else happens. How do I fix that problem??
von
Antwort hinzufügen
roger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 512
