Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
The Dremel 8220 variable-speed cordless rotary tool offers the highest performance of all Dremel cordless rotary tools. Released Date: June 22, 2012
6 Fragen Alle anzeigen
Why can I put an attachment on my device?
I want to attach the sanding wheel to my device but it won't fit. I'm using the attachment heads that came with my device.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Assuming you are using the correct attachment heads, your problem is most likely the collet. If the collet nut was screwed too tightly at some point you could have damaged your collet, which is the small metal piece that holds the attachment head in place. Refer to our repair guide on how to replace a collet if you believe this is the issue.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
connor anisko wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 83
