Zum Hauptinhalt wechseln
Repair and disassembly guides for Kenmore Microwaves.
179 Fragen Alle anzeigen
Why is my microwave dead
Is there a fusible link or internal breaker? I shorted my microwave out changing the lightbulb over the range. Now there is no power anywhere on the microwave. The outlet still has power.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
4 Kommentare
Please give us a model number
von
Model number is 85513
von
I have a kenmore model 721.80803400 and just replaced the light bulb. It got stuck and broke off. I did not unplug the power and did stupid mistake of tweezers to remove the plug and bang no power. Tried to reset the circuit breakers in the house (main) on and off and then checked the plugs outlet and they work. Tripped the wall and the appliances all work but not the microwave. Is there another switch on the microwave to hit power?
von
Does anyone have the Manuel for this microwave? Size? Power? Do you think it's good? Thinking of buying a second hand one. Thanks
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
@luker your microwave has a fuse on the inside by the power supply. That's where I'd start. Double check your model number. I would have expected a 3 digits prefix. See if it does show anywhere. Reason why I ask is that Kenmore really does not build microwaves but those are rebranded. Could be made by Samsung as well as many others. Anyhow, fuse should be in the same vicinity as part 5001 in the image.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
Thanks for the help. My wife will be happy if I can fix this.
von
thank you, but where is the fuse
von
@nier101
What is the model number of the microwave oven?
von
My microwave is a Kenmore model# 970-86113-001
von
You might need to look at your house power Panel to see if your Microwave has a dedicated circuit breaker to see if is tripped. Or if there is a power plug trip circuit (a little red button) on the power outlet. If that tripped then your Microwave might not be getting power. Press the red button or if it is a circuit breaker reset the power.
Bewertung 0
1 Kommentar:
The outlet that it is plugged in to still has power so I see no sense checking the hydro panel. Any other ideas of an internal fuse or something of the like.
von
Hi Luke. In 2016 you posted on ifixit that you shorted your microwave while changing a light bulb. I just did the same thing. How did you eventually fix it? Replace an internal fuse?
—Frank
Bewertung 0
1 Kommentar:
Hey Frank, I had the same problem. Opened the microwave, checked the fuse. It was blown, bought @ Homedepot - $3.50 package of 2 - 20A/250V microwave fuse. Cheap fix.
Dave
von
Antwort hinzufügen
Luke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 117
Insgesamt: 15,410
