Charge port replaced still no power
I've got a kindle fire D01400 that I've replaced the charge port on. The port had the common problem of falling away from the board. After attaching the new port, I still get no signs of charging or power. I've been fixing many Nintendo handhelds with common problems and thought that I should check some fuses on the board. Problem is, I can't locate any fuses at the moment.
Has anyone had any luck fixing this issue with the Kindle Fire? If so, what did you do and where is/are the fuse(s) located at?
Thanks for the help gang!
Ist dies eine gute Frage?
