Zum Hauptinhalt wechseln
Model A1320 / 8 GB oder 16 GB Speicherplatz
iPod Nano charges but won't connect to USB on any computer
My iPod nano suddenly stopped connecting to any computer.
When I plug it in it will charge, but not connect, it doesn't show up in iTunes, explorer, disk manager or device manager. The iPod is otherwise fully functional.
Things I've tried:
Hard Reset (both when connected and not)
Disk Mode
Original Apple cable, and aftermarket cables (charges on all, won't connect)
Uninstalling iTunes
Restarting computer with iPod attached
Uninstalling all USB drivers and restarting
Plugged into Windows 7/10 and OSX, no change.
I even tried connecting it to an android phone with an adapter .
Reset iPod settings
I am pulling (what little is left) of my hair out with this! I have come to the end of the internet and I've run out of options, the only thing left to assume is that it's a hardware issue but it was literally working, then sat on a desk for a bit, then stopped working, nothing happened in between and it never had any issues before.
Any insight is appreciated, even solidarity if you are experiencing the same thing. It's just so frustrating, at least if it showed some sign of connectivity I would have a glimmer of hope, but I have nothing to go on if I can't even try to access the device.
SIGH.
Thanks,
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
I fixed this problem by first disconnecting the device from the USB cable and restarting the device. To restart (ipod nano 2nd gen), hold the middle button and the menu button until the screen goes dark (i let go when it darkened and it still worked) After a short wait the apple logo should appear. Wait until your device powers on and shows the menu. Now your device should connect to your Mac/PC. Note this will NOT erase your data, just restarts the device.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
Thank you so much i will truly be eternally grateful
von
This totally worked for me! Thank you!
von
Boomshanka! Thanks VERY much - worked a dream. And... why didn't I think of this earlier?
von
it doesn't work
von
This worked for me! Thank you very much! Ipod nano 2nd.
von
i have that same problem -sad-
Bewertung 1
It is a hardware issue but the question is what hardware, try any of the cables on another device and see if the computer sees it, if it does then it is the iPod (most likely some of the pins on the port are broken) and... Ya.... Nothing you can really do...
Bewertung 0
1 Kommentar:
Sadly I agree that it's likely a hardware issue. But I don't understand how, it worked just fine, then sat on a desk for a bit, then didn't work anymore. I suppose I could try to replace the logic board if I can find a replacement. I'm looking for my old 80GB iPod video to connect and see if my computer will recognize that. At least I can confirm then that it's a hardware problem and not that apple has put a curse on my house or something, haha.
von
Have you tried holding the menu button & the ok button at the same time on the iPod?
Bewertung 0
Hi all
Im not able to restart my ipod annao 2nd gen, pressign centre nd menu button int working but but works properly,
Bewertung 0
Antwort hinzufügen
Joseph wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 38
Letzte 30 Tage: 156
Insgesamt: 6,992
