Zum Hauptinhalt wechseln
Dieses Modell der HP 2000-Serie wurde im November 2013 veröffentlicht und ist das perfekte Gerät für alle, die ein begrenztes Budget haben, aber bei der Leistung keine Abstriche machen wollen.
Won't go off of update screen!
My computer screen is blue and says "We couldn't complete the updates. Undoing changes. Don't turn off your computer" it had said this for over 3 months now and I can't seem to fix it or get it to get off!!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
sadly this requires a factory restore. this is a problem with Windows 8, 8.1, and 10. these errors are caused by a disruption during an update like closing the lid, the battery dying, or a failed internet connection durring the update download
War diese Antwort hilfreich?
Bewertung 0
I’d start by going into the BIOS and verifying the time is correct, then go back into the BIOS and do a system diagnosis. Check the RAM, but it usually passes. Then check the hard drive. Let the test complete. If it passes you will need to reset or reinstall your operating system. If the hard drive is bad, remove it and gently shake it to check for any sounds. your hard drive should remain silent, a noisy hard drive should get replaced. Best place for parts is ebay-never by any hard drive used, always new. If you don’t have your operating system disk, Microsoft offers them free if you are willing to enter your product key. Linus operating Systems are free to download from distrowatch.com. I use nothing but Linux Operating systems, they are easy to install, they replace Windows or allow a dual boot. Remember to add the dvd drivers, flash. I use Whale Browser. Personally, I’d check the fan and replace the thermal compound on your CPU. Never took a computer apart before? Go to youtube and type in your device name along with what you want to do. It’s much easier than you think
Bewertung 0
Antwort hinzufügen
whitneybug29 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 521
