Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
12.1" netbook released in September 2010. Powered by an Intel ATOM D525 dual core processor running at 1.8 Ghz and NVIDIA ION graphics processor.
3 Fragen Alle anzeigen
How to fix SQL database?
We have a legal program that uses SQL express 2005. Somehow the company is saying our database has become corrupted and needs to be sent to a company to be rebuilt or fixed. The database sits on an external hard drive. We had to reload windows on the machine that it sits on. when we tried to reattach the database afterwards, we couldn't. Is there a cheap or software out there that I can use to fix it?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
Manta Precision Bit Set
112 Bits für jede Reparatur.
Upgrade Your Toolbox
2 Antworten
Gewählte Lösung
So you have only the .mdf and .ldf files?
The only thing left to try is:
1) take a copy of the ORIGINAL .mdf file (it's far better if it's the file as it looked BEFORE you attempted to attach it -- the attach attempt itself will modify the file)
2) if the db has only the one primary fg, attempt to do a "sp_attach_single_file_db" on the file.
If it has multiple fgs, primary and one or more secondaries, you will have to use CREATE DATABASE ... WITH ATTACH_REBUILD_LOG
For example, select "New Query" from withn Express, then issue this command:
EXEC sp_attach_single_file_db 'Db_Attach_Test',
'x:\path\to\primary\data\file\primarydatafile.mdf'
Of the programs I can recommend to you SQL Server Recovery Toolbox if the above suggestion don't help. I hope everything works out for you. http://www.oemailrecovery.com/sql_recove...
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
Also have a look this Recommended actions
http://itknowledgeexchange.techtarget.co...
von
Execute the following query
ALTER DATABASE test
SET emergency
GO
ALTER DATABASE test
SET single_user
GO
DBCC checkdb (test, repair_allow_data_loss)
ALTER DATABASE test
SET multi_user
GO
BUT be careful: REPAIR_ALLOW_DATA_LOSS means that some data might be lost in the DB even if it attached successfully. If you want to recover your data without any loss then you must go with third party SQL MDF Recovery Tool
Bewertung 0
Antwort hinzufügen
morrison wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 120
