Zum Hauptinhalt wechseln
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
It turns on OK but the screen remains white.
The laptop turns on as normal but the screen is white and I am unable to do anything with it. If you tilt it, you can see that the left half of the screen has very light blue vertical lines, in different shades / sizes and patterns. My dog 'may' have stepped on the closed lap tap. Could the pressure from the dog damage the screen???
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hey tinazinger,
Yes, It doesn't take much pressure. They usually crack under the black tape that surrounds the actual LCD. They run around $40-$50 on amazon and pretty easy to change. Get the number off the back of the original LCD before ordering to insure that you get the correct one.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
tinazinger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 892
