Can see no gas filter in line. filter in gas tank?
in line shows no gas filter. filter in tank? gas cap shows no vent hole.
Ist dies eine gute Frage?
Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine
fuel filter is optional. Here is the maintenance manual. See page 6 features and control letter N
War diese Antwort hilfreich?
There is no fuel filter at all? No vented gas cap
Ive had issues with my Briggs which had no filter.
I had to keep remving the crab and cleaning the jets.
Finally I just cut the fuel line and put one in.
It works fine now...
If I where you Id go get a cheap inline filter
then take off the carb and REALLY clean it.
Use small wire to run through the tiny jets and lots of carb cleaner
last NEVER use ethonol gas in it.
I go to my local small plane airport and buy AVGAS which is regular unleaded HIGHER octain
with NO ethonol.
Its cheaper to buy it this way then in the quarts in brand names like TRUE GAS etc
good luck
Royal Farms sells gas with no ethanol.
AVGas is leaded. MOFuel (Motor Vehicle Fuel) is not leaded and has no ethanol. Both can be found at small airports. Do Not use AVGas.
Letzte 24 Stunden: 8
Letzte 7 Tage: 37
Letzte 30 Tage: 95
Insgesamt: 15,395
