Zum Hauptinhalt wechseln
1,8 GHz Dual-Core Intel Core i5 (Turbo Boost bis 2,8 GHz) mit 3 MB geteiltem L3-Cache
371 Fragen Alle anzeigen
Failed trackpad and keyboard
Hi there!
Working with a MacBook Air 13" Mid 2012. Trackpad and keyboard failure arose after minor water damage (water likely entered from ventilation holes as keyboard was covered with silicon protector): everything except the power button malfunctioned.
Replaced the upper case cable and the problem was resolved until a week later, when the same failure recurred.
Any diagnosis and recommended repairs welcomed. Thanks!
MacBook Air 13" (Mid 2011-Mid 2012) Trackpad Cable Bild
Produkt
$14.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Update: I've replaced the upper case cable a second time to verify that I've not received a faulty cable. This time, the repair did not resolve the problem, even temporarily.
von
Update: For no apparent reason, the trackpad and keyboard became functional again. I was in the middle of browsing a website on my bluetooth keyboard and trackpad when they suddenly became unresponsive and the built-in hardware kicked back into life. Very confused. Would appreciate additional diagnosis based on this development as I anticipate the hardware to fail again in the near future.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
See how an external keyboard works, Examine the logic board of corrosion and try to determine the entry point. This sound like a keyboard entry despite the protection.
UPDATE 6/4/16
Here's where I originally ran into this issue and then the fix that worked for me:
Trackpad Does not Function Properly
War diese Antwort hilfreich?
Bewertung 3
11 Kommentare:
Thanks for your attention and consideration. Both USB and bluetooth mice and keyboards have worked since the first moment of the initial malfunction. I'm not familiar with the full range of what corrosion looks like, but there's no sign of the kind of corrosion I've seen via a google image search on either the logic board or trackpad. If you have a moment to confirm, I've uploaded photos of these areas to http://imgur.com/a/XMv1t
von
I see no evidence of logic board corruption. However it does sound like your keyboard has failed. I've this kind of issue arise with liquid hitting the trackpad alone. Is that a possibility? What leads you to believe it ws water damaged?
von
The problem first arose immediately after some water dribbled onto the laptop (a minor spill). I thought it hit the top of the keyboard but it may well have seeped in through the trackpad as well. Would a failed keyboard be consistent with my experience of temporarily resolving the issue after replacing the upper case cable? Thanks
von
I need you to first make a Time Time Machine backup of your data, then I walk you through and show what I've done to fix it in the past.
von
Back up complete!
von
6 weitere Kommentare anzeigen
Check to see that there is no corrosion on the connectors or the cable, also it could be that the area actually failed now that it got power after the water damage.
Bewertung 1
1 Kommentar:
Thanks for your attention and consideration. I'm not familiar with the full range of what corrosion looks like, but there's no sign of the kind of corrosion I've seen via a google image search on either the logic board or trackpad. If you have a moment to confirm, I've uploaded photos of these areas to http://imgur.com/a/XMv1t
von
Antwort hinzufügen
Don Sweetings wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 267
