Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
465 Fragen Alle anzeigen
Is it possible to replace the trackpad?
My trackpad isn't working at all - I've fiddled with all the settings etc, but no joy.
I'm wondering can I at least take the batteries out (like in the earlier models with the iOpener) to check the zif connector, and hopefully, if necessary, to replace the trackpad...
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Yes, I can fix it without destroying battery. But first tell us what happened.
von
My trackpad started acting up, the "click" started to not work - mainly on the right side; my predominant side. The left side still can "click." The right side still can initiate a click operation but with more force needed and there is no click. Is this a sign of impending failure of the trackpad?
Thanks in advance...
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Yes you can change the trackpad but you have to get the battery's out and that is no fun task, (or to put them back) the best way is to get something to remove the glue under the battery's, heat won't do anything to the glue as the battery's are to thick... You may find this video useful;
https://youtu.be/pLhHSIej9fs
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks very much Ethreal1.. that's just the answer I need, just need to get myself my tools now and get to it!
von
Antwort hinzufügen
Brian McCrum wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 124
