Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
797 Fragen Alle anzeigen
New Battery: Why is the"Very low battery sign"still on after charging?
Hi I just purchased a new battery and front along with a click wheel for my ipod video from Ifixit. I have followed the instructions but once done I get the following 3 screens:
1:Please Wait. Very Low Battery
2:Black screen with apple emblem
3:www.apple.com/support/ipod
I have tried to reseat the battery cable more then 4 times with the same result each time.
I have had the ipod charging all day, so over 8 hours.
Any ideas or suggestions would be greatly appreciated. Thank you
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
How long has it had a chance to charge?
von
The first time over night the second time I tried to reseat, 4 hours, the last time about 8. Thanks
von
Did you get it fixed by now?
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
I had the exact same issues. I disassembled my ipod, rechecked all the connections and still ended up with nothing I ended up replacing the motherboard. That did the trick. Apparently there are some issues with the charging circuit on these boards. It is also possible that it won't charge because it doesn't have enough juice to start charging so it just continously resets itself. You need to have it hooked up to your computer in 'disk mode'.
1. Take your iPod and plug it in to your USB port.
2. Hold down the select [center button] and the play button.
Use a USB port that comes directly of the motherboard. Do not use a frontport or a hub when you connect your iPod. It might have to update your library but you shouldn't lose all your music.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Sometimes it is a firmware issue, the problem here is that your computer does not recognize it. I try to restore it under itunes if you get it recognized. There is really not a lot you can do since you already replaced all the parts except the main board. again make sure all your connections are nice and snug and that your new components don't give you any trouble. The only other thing that I would try is to charge the battery either through firewire connection or a wall charger. Let us know how it is going....good luck.
von
This actually works! thanks! My Ipod Video 30GB is now alive!
von
maybe it's the charging board itself or maybe you have to reinstall the firmware after replacing the battery. i don't know. sometimes these things have to be reset
Bewertung 0
I was thinking that too, as a second battery was provided but it still does not work. I am at the point where it is beyond my ability and will send it to some place to have it fixed.
Bewertung 0
I have the exactly same problem :(
Hard drive is not spinning and my computer is not detecting the iPod.
I've already replaced so many things, don't tell me my motherboard is broken :(
Everything was fine with old battery (I threw it away, unfortunately).
I also replaced the hard drive but reinstalling the old one did not help.
Any ideas?
Bewertung 0
1 Kommentar:
I would definitely start thinking about replacing the logic board. Sorry
von
No I need to buy a new logic board for it I think.
Bewertung 0
1 Kommentar:
Probably right decision. Like I mentioned before it could be the charging circuit, but its still part of the logic board and hard to fix for the DIY'er. The part of course is available here http://www.ifixit.com/iPod-Parts/iPod-Vi... as well as many other places and a relative easy fix. Good Luck to you.
von
If you replaced the battery and are now seeing this error, the 'new' battery may not actually be new, if it was sitting in a warehouse for years the battery would have gone completely flat and the lithium went bad.
When a battery drops below a certain voltage it cannot be recovered and needs replacing. Lithium batteries should be stored at around 50% charge, and recharged every few weeks to keep it in good condition.
Bewertung 0
Antwort hinzufügen
alos31 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 16
Insgesamt: 17,571
