Cellular antenna connection points?
Hello, have been trying to fix my iphone for days now. Got the searching...-text in the top corner and have tried replacing cellular antenna assebly down at the bottom two times. Then it has worked for a day or two until it hasnt anymore. Today I opened my phone, took out the speaker, and put it in again. Then it worked when I pressed on the screen in the speaker-area so, pretty sure there is bad contact somewhere. Anyone know where all the antennas connection points to the chassis are so I can try and get it working again?
Thankyou in advance!
Ist dies eine gute Frage?
3 Kommentare
Not really 100% sure but there is an antenna cable plugging from the charging dock assembly to the logic board bottom part. Then there's a few more antenna pieces at the upper part. I think the one on the top left of the logic board is for the Wi-Fi (It actually connects under the logic board if I'm correct) and the top right part of the logic board also has a few antenna contacts which have screws to hold them in place.
von Ben
Yea but the antenna that comes from the dock assembly, where is that connected to the chassis if it is at all?
von nordaune1995
@nordaune1995 it's not connected to the chassis, just the logic board and the charge port flex. It does nestle in the upper left corner of the loudspeaker that sits right near it, as it passes through to get to its connector on the logic board. You'll see a groove in that upper left portion of the loudspeaker module where the cable sits when everything is tied down.
von Doots
