Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Won't turn on after drop
A customer brought me their iPhone 6(model a1549). They claim to have dropped it and after that it wouldn't turn on or charge. I got a replacement display and put it in, but it still won't boot or charge. When I plug it into my desktop iTunes doesn't even recognize it. Got any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Thanks! I'll try these things out and see.
von
Try what Ben said. Same thing happened to me.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Usually the charging IC chip. Have you tried a known good working charged iPhone 6 battery to see if it turns on? If it turns on successfully, try plugging in a charger. If it doesn't charge then it's probably the charging IC chip.
Note that you should check the charger port for any dust blockage as it may stop the lightning cable from plugging into the port fully.
Usually they are cleaned with tweezers, toothpick or some equivalent tool.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
jlowry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,220
