MacBook Pro Mid 2012 No Backlight
I have a Macbook Pro, serial ending in F5WV, that was purchased refurb from apple for a employee to use. It last about 6 months until it was brought back to me for having no display. I did some digging and I have come to the conclusion that the backlight is the issue.
-I can do the flashlight trick and see my apple logo and users etc.....
-I can hook it to an external monitor and have it work perfect.
-I get a tiny little flash every time i boot but other than that the screen shows no life unless the flashlight is held up behind it
I have located the fuse and the driver but when i go to check the fuse the board shorts and cuts off. Obviously i am not finding the correct ground.
Any help with this issue would be GREATLY appreciated!! Even if its just helping track it down to the fuse or the driver!
Ist dies eine gute Frage?
2 Kommentare
@tylerh It should not short out or cut off when you check the fuse. Mark the fuse on one of your images. What 820-XXXX is your board? How did you check the fuse? Why do you have the computer on to check it?
von oldturkey03
@tylerh any news on this? I have the exact same problem! I don't even know how to "check" the fuse or where is it... OldTurkey03 is helping me too hopefully. Thanx
von Alex
