Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
5058 Fragen Alle anzeigen
Replacement screens and not work
The other day my phone shattered after I dropped it. The lcd and screen were working though. I decided to replace the screen myself.
I ordered multiple replacement screens but none of them worked. I even used a screen from another working phone. The screens were all blank and the backlight didn't work either.
I've tried all the generic solutions (hard reset, replace battery). I could still hear the phone vibrate so it's not a battery issue. It's also not long screw damage.
All help would be appreciated!
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
I think there is some damage on the logic board specifically on some components probably.
Have you tried turning the phone on and see if it shows some signs of light on the screen with the screen lifted up and you looking behind the display? Not really sure if you can see it on the iPhone 6 screens behind.
von
does your old screen still works when you put it back?
von
Einen Kommentar hinzufügen
1 Antwort
Did you disconnect the battery when you did the screen swap?
iPhone 6 series is very unforgiving when it comes to shorts. If you had the battery connected and unplugged the display, you very well could have shorted something out and broken the phone.
Try putting one of the displays on, connect the USB to your computer and the phone, then hold down power and home for 30 seconds. If iTunes sees your phone, you know that something isn't seated right. If iTunes doesn't see your phone, then you have blown something up and it will not be a cheap fix.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Aru wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 57
