How to adjust rocker arms on 4.0
how do i adjust valves
Ist dies eine gute Frage?
Betty Ayers your 4.0 Ranger has hydraulic roller cam followers (lifters) and you do not adjust hydraulic lifters. If you have valve noise etc it is possible that you have some pitted or worn push rods. If you let us know what makes you think you have to adjust your valves, we could possibly help you further.
War diese Antwort hilfreich?
4.0 was bad for lifters going solid. The lifter stops taking oil it deflates and stays solid causing push-rods to ring. this is usually followed by a failure of the timing chain
Is there anything I can do to quiet down how about if I just put new push rods in
Or is the rocker arms bad too
@john76866 only you will know if the rocker arms will be bad. I prefer to replace both of those (rocker arms and lifters) since that way I do not have to tear it down again. Yes. it's an additional cost but it evens out since I don't have to tear it down again
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 40
Insgesamt: 2,685
