Zum Hauptinhalt wechseln
Das Galaxy S6 ist das neue Flagschiff der Galaxy-Linie. Es wurde im März 2015 angekündigt, Verkaufsstart war am 10. April. Die Version mit dem gewölbten Bildschirm ist unter Galaxy S6 Edge bekannt.
486 Fragen Alle anzeigen
My wifi and Bluetooth won't turn on
Is the wifi board located on the midframe or is it directly on the board. I have an issue with my S6 with the wifi and Bluetooth not turning on at all. Tried multiple restarts and factory resets I just noticed that I have no sound either so the speaker on the midframe seems to be toast as well. Would you think this is the midframe contacts causing this issue? If so how would I repair this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
Phone still got warranty? Get it replaced. Otherwise the Wi-Fi ic / chip needs to be replaced.
von
has the phone been opened?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The wifi/bluetooth chip is soldered directly to the motherboard. Sounds like the phone has probably experienced a substantial impact at some point, but there could be other causes. If your frame is bent I find it unlikely that the speaker contacts would have lost contact. Either way, your wifi/bt issue will most likely require a board level repair to replace the chip. You want to be very selective about what shop you let attempt this. An inexperienced tech could easily make this bad situation worse. Either way, I cant see it costing less than $125 with around a 10 day turn around time if you can find a reputable repair shop and have to send it off. I would personally contact iPad Rehab in New York and ask if they'll take the repair.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Of course there's always the possibility that some files in the system partition have somehow become corrupted, in which case a factory reset wouldn't help. In that case you'd need to reflash the phone's stock software from a computer using the Odin tool and a tar image of your phone's firmware. But again, this sounds more like hardware to me
von
I have already tried a different rom and re-flashed the stock rom via Odin to no avail. I have also removed the board and checked it over and also cleaned the contacts with iso (99%) alcohol. Im assuming now I have a motherboard issue which is unfortunate because I love the phone and also have the GearVR which is virtually pointless to have with the phone with no wifi/Bluetooth or sound lol
von
Hi
I have the same problem i trots everything that is possible , diffrent firmware, hardreset, flash with Odin and z3x . The problem is in the logicalboard but i dont see which one is the wi-fi ic.
Bewertung 1
lenovo a536 didnt had any sound coming from it wether its from video or music files even ring tones. fixed it just by turning the phone of and taking out the battery for couple of minutes and inserting it again and turning the phone on its that simple
Bewertung 1
Antwort hinzufügen
Jamie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 40,783
