Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Das erste iPhone Modell, A1203, mit 4,8 oder 19 GB Kapazität und einer Aluminium-Rückschale. Bei der Reparatur muss gehebelt und möglicherweise auch gelötet werden.
289 Fragen Alle anzeigen
Why doesn't my new battery work?
I went through the instructions. Getting the case off was difficult. De-soldering and re-soldering the battery went smoothly.
After re-assembly, I put the iPhone 1st gen into a dock to charge. It simply flashes the start screen (apple on black background) -- about 5 seconds on and 2 seconds off.
Perhaps the soldering wasn't perfect? Perhaps there's some other physical problem?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
2 Antworten
Hilfreichste Antwort
I have the same problem. I checked the new battery voltage and it is only .245Mv, therefore, I think it's a bad replacement battery. The old battery shows 3.79V. So, I think I will try putting the old battery back into the phone and check again.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
+ sounds like a good plan to check voltage of batteries
von
Yes, it was just a bad battery. ifixit quickly sent a replacement and the new battery worked fine.
von
just check you haven't got the solder spots too close and a shorting iphone
Bewertung 0
Antwort hinzufügen
andrewvoelker wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 757
