Zum Hauptinhalt wechseln
The economical version of the Samsung Galaxy S4, released in July 2013.
99 Fragen Alle anzeigen
Why can I get no network access
Hi, having just repaired an s4 mini, which is locked to EE, I've put my normal EE sim card in the phone, but get no network access at all. When the sim is in my other Samsung, there is a good signal. Does anyone have any ideas what the problem could be? I can save contacts to the sim card, so I think the sim reader is ok. Could it be an antenna? or is there another part that could be at fault.
Many thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
6 Kommentare
Are you on the stock software?
von
Hi Ethan, yes. Standard software.
von
By no network access, do you mean that you don't get a signal, or it gives you an error when trying to call someone
von
Actually both. Circle with a line through it at the top of the screen. If I try to make a call I get a message saying there is no network connection.
von
Hmm do you have all the required antennas properly inserted?
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hey Bigphilly71,
I would recommend you contacting your provider, maybe they can help you! Also, check your motherboard if everything looks alright.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Bigphilly71 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 499
