I've seen this happening with a Phantom 3 standard before. For me, it wasn't the battery or the cable, but the actual USB connector on the controller. It seemed like they didn't do a great job in the factory soldering the USB connector to the printed circuit board that it sits on. Once you've ruled out that your issue isn't a bad USB cable/charger, you may want to consider this. If you look at this picture, you'll see that the USB port is attached to a little circuit board that is wired to the rest of the controller. I was able to repair the connection between the USB connector and that board with a fine-tip soldering iron, if you're handy with a soldering iron you may want to try the same. If you aren't experienced with a soldeirng iron, I was able to find a replacement part on eBay (but nowhere else so order soon!).
Good luck!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
I have the exact same problem. I have only used it once!!
von Derek Scott
I'm in the same boat however, mine will flash the one led for a few moments and then will stop.
von manchesterman96
Same problem with my phantom 4 RC. Send to repair, happen again after 1 month.
von BT LOH
Just wanting to know PS, XBox, Nintendo Wii etc... and when it is plugged in, does the controller work normally when it is plugged in? Can you play if controller is plugged in?
von sirozmonster
Yes. Does this mean it is simply a bad battery?
von Charlie Gaines
1 weiteren Kommentar anzeigen
