picture on screen looks like a negative picture
picture on screen looks like a negative picture of a photograph
is this repearable
Ist dies eine gute Frage?
is this repearable
So if you tv is showing negative colors on your Samsung tv hold down the volume button and go to high Contrast and turn it off it should fix it :)
War diese Antwort hilfreich?
you fixed my problem, it took 30 seconds. Thank You. Very good advice.
This is the most simple fix.
Your comment should be on TOP
We can't hold the volume button down and go to contrast at the same time, I don't know what you mean?
don't hold it down as in turning volume down but hold it down like pushing it in it will bring up a menu after holding it for a few seconds I cannot believe how simple this fix was thank you so much.
Have this problem with a Panasonic, will the fix be the same ?
I had the same thing with a samsung as well.
In that tv the problem was a bad ( polluted) t con flat cable. i cleaned the contacts with isopropyl. first remove the dust.
if this doesn't work : try to check the Pcb of the T con board. probably a bad IC. ( as15.. )(most of the time)
try to measure out first if thats possible.
if you are not sure, send us some pictures when you open the tv. we will show you what the t con board is.
Kind regards,
kevin
I had the same problem and I found something called picture inversion and shut that off and now it works fine.
Not sure of the model number but it's a 55 inch Samsung curved screen. Hope this helps.
Volume button just turns the volume up or down mute will just mute the set. It seems like when the set gets to operating temperature, and the set is then power cycled, when the set is turned back on it will go back to normal. This leads me to believe it's a loose or dirty connector that expands with heat.
when playstation is connected they tweak the tv using the functions an do things not even on the tvs menu so you have to put ps back on an tweak it back to normal.. some stuff is in the accessibilty thing like invert colour..
hi i dont understand hold it down like pushing it in it
Samsung universal remote
The newer Samsung TVs don't have volume or contrast buttons on the front panel. However, if you experience the inverse video issue, you can fix it using the TV remote's SETTINGS feature on the remote. Go down to General and turn off Inverse Video. Then exit SETTINGS to return to the normal color. settings
When I view recordings or menu page for Amazon prime, the images are displayed as negative, but this disappears when I start the viewing. Anyone help? My tv is LG 4K 49 inch.
HOW TO FIX: I don’t have a tv controller or settings on my Samsung tv, but I hit the back of my tv and disconnected the power cord or DCV, DC ,DV thing I don’t know but I disconnected that and connected it and then turned my tv back on and my screen was back to normal, hope that works for whoever had the same problem.
Letzte 24 Stunden: 32
Letzte 7 Tage: 178
Letzte 30 Tage: 695
Insgesamt: 147,035
18 Kommentare
my picture is All Bright Like the brightness is up too much but I turn brightness all the way down and still looks the same we're going to do to fix this and it doesn't matter what plug-in part I use picture always looks too bright can't even really see anything
von tim allard
when i pull up pictures, they appear to be the negative
von Roger Taylor
My Samsung 4k 55 inch TV randomly turned into a negative inverted color. I tried to reset settings and it didn't work. Is there anything else I can do.
von Ang M
Hello, I have a samsung 4K as well and one week ago when I switched on the tv the picture looked like a negative. For the first few days it took a minute or two and then returned to normal. However now it takes 15-20 minutes to return to normal. Can anyone help?
von janeamies
@alberius Go to Settings > Picture>Accessibility >Colour Inversion and switch it off. It will resolve the problem.
von Bioscope wala
13 weitere Kommentare anzeigen
