Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 5 ist eine Kombination aus Mobiltelefon und Tablet von der Firma Samsung. Es kam im August 2015 auf den Markt.
271 Fragen Alle anzeigen
phone doesn't boot up
phone doesn't reboot. i turn it on and it just keep restarting with the unlock logo and samsung logo. what happend was i was on the call and phone suddenly shut off and went blank. i tried to turn it on and now its does the same thing as i have explained above.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi
Try putting phone in download mode and see if it stays on:
To put in download mode press the power+home+volume down button together, then it will show the download mode and press the volume up button to enter download mode.
Leave it on that mode for a little bit and see if it turns off. if it does then the problem is the motherboard and should be covered under the manufacture warranty. You can contact samsung or your provider for that.
If it does not turn off then put your phone in recovery mode and reset the phone and wipe cache. to put in recovery
Turn off your Samsung Note 5.
Press Power , Home and Volume Up buttons together and hold them.
Once you see the Android System Recovery screen, release the buttons.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
ajmal78 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 80
