Zum Hauptinhalt wechseln
Quad-Core-9-Zoll-Android-Tablet, veröffentlicht im Oktober 2014, identifizierbar durch die Modellnummer ME-9Q
Why does my tablet only turn on when connected to the charger?
The tablet only turns on when it is connected to the charger. It turns off immediately when disconnected. Is this a problem with the battery or the charger?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
This could be a problem with the charger jack but is most likely caused by the tablets battery. First verify that your charger is functioning properly. Then be sure to let the device charge for longer than 30 minutes. If the device still shuts off, then replacing the battery may be required.
War diese Antwort hilfreich?
Bewertung 0
It could be a cold solder joint where the battery is connected to the main logic board. Check with a magnifying glass and re solder if necessary.
Bewertung 0
I’m with Ken I had to buy a new battery, when I had this issue now it works great.
Bewertung 0
Antwort hinzufügen
Joseph Justice wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 509
