My fan is making a lot of noise.
I need to get a new fan for my computer but am having trouble finding one also how do I take the cover off so I can replace the fan?
Ist dies eine gute Frage?
Try one of these guides to see if one is similar to your Toshiba. It will help you to get to the fan.
As for finding a fan, try notebookpartsshop.com, eBay or Amazon. I'm sure one is available to purchase.
Also, checkout this forum on loud Toshiba fans.
War diese Antwort hilfreich?
Thank you I will try to remove fan and give it a drop of oil.
Hello ! I have the same probleme, how did you remove the fan ? I dont know how to open the computer to get it.
Thanks a lot
If you change to a new fan then it's best to also clean the core of the CPU with some isopropyl alcohol.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 5,339
1 Kommentar
I had a lot of problems opening the computer but did do it and did fix it by just cleaning the fan and oiling it with sewing machine oil I have one screw left over could not work out where it came from.The good thing is it is very quiet now and runs much better.
von Peter Johnson
