Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Why the device doesn't turn on with the new display assembly?
After the display assembly replacement, the device doesn't turn on, but only shows (full screen) the battery (as if it would be out of charge) and the lightning plug icons.
Once I plug it in, only the battery icons remain, and if I disconnect the battery (while the plug is in) it shows the apple logo for a few seconds and then gets shuted down.
Is there something I could try before contact the vendor asking for the replacement?
Thank you all ^^
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try disconnecting the battery and reconnecting it again after a few seconds. I had a similar problem and this worked for me.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you Klaus :) it tooks me a bit more than a few seconds, but it finally works!
I also had to keep it under charge for a few minutes (as suggested by the support).
Btw, thank you again!
von
Yeah, usually this means battery is flat or bad contact with both the battery connector and the battery ribbon cable plug itself, replugging it solves this issue most of the time.
von
You're very welcome, glad it worked:)
von
Usually there are 5 possible reasons for the problem:
1. Power Distribution Issue
2. The Dead Battery Issue
3. The Damage Board Issue
4. Assembly Issue
5. Problem with Flat Cable Connection
You can find more details here: What to Do When iPhone Won't Turn on after Screen Replacement
Bewertung 0
1 Kommentar:
Sorry, but I can't follow the link.....just says 404
von
Antwort hinzufügen
Rocco Lorusso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 98
