Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
Why is my iPhone searching for service/no service?
Hello, this is the first time posting here and I would like some help if possible.
I recently purchased an iPhone 6 Plus with a shattered screen (it worked fine had no SIM card though) from a friend. When I put my SIM card from my iPhone 5c into the new phone (didnt go to my verizon store yet) the 6 plus would have an active cellular reception. Heres the problem, after a while, the phone will lose service and begin "Searching for Service" or just say "No service" and it will randomly swap between working fine and having no service.
also, I use Verizon, and the phone is from the verizon network, but for some reason, right before it lost service most recently, instead of saying "Verizon" in the top left it said "Extended" which I thought was weird. I took it apart to replace the screen and I noticed what looked like the brown syrup from dried soda, so i assume soda has been spilled on or near this phone before :(
Any help will be appreciated!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hello,
Same symptoms in my iPhone 6 too
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I dont think anyone will help us... sadly
von
It seems to me the board suffered from liquid damage. What i would recommend is inspect the Sim Card area inside the phone for any signs of that substance you saw and if there is get a Qtip with 91% or 99% alcohol and scrub it off hopefully that should do the trick. If it still doesn't work then a component maybe damaged i would personally have to look at the phone. Best of luck!! :)
Bewertung 0
2 Kommentare:
Thanks for posting!
von
No problem!! :) hope you can get you're phone working again.
von
Antwort hinzufügen
Thomas Crenshaw wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 196
