Zum Hauptinhalt wechseln
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
How can I repair My Canon EOS 70D no power
My Canon 70d died while after recorded video and review it. It is hot and shut down. I also removed battery, restore and turn on again. But it is no power. Can repair that in this saturation ? I already sent to the shop where I bought the camera.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
When you powered it on again did you wait a few hours? Just thinking outloud... maybe it has autoshut down parameters when it gets too hot to safeguard against damage. What is the speed rating on your SD card? Is your SD Card AFtermarket or genuine. At those temps the battery was probably drained completely. If indeed the board is fried then you will need to replace it. Your repairshop should be able to
determine.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sai Taitai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 1,077
