Zum Hauptinhalt wechseln
Why won't my computer work?
So I have a Sony Vaio that I fixed a while ago. The original problem was a faulty hdd. It was fixed by formatting (or re-partitioning I chat remember) and installing Windows. It's worked for a couple of months until this morning when I turned it on and it threw up a "error code 0xc00000e9". I disconnected everything's plugged into the laptop (besides power) and tried again, to no avail. Last night I installed a game (I played it until I shut of my computer) that may have contained a virus. Since you can not boot into bios in Win 10 I put the inatalation disk in and turned it on again. However, after it reaches the troubleshooting menu, it simply reboots, giving me no time to fix the problem. After taking the cd out, to try and restart it, it now shows "A disk read error occurred. Press ctrl+alt+delete to restart". However, doing that does nothing. Can this be fixed? And if so how? Otherwise, I might just buy a SSD start from a fresh computer (I have no backups :( ).
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi. Can You provide your BIOS settings. Look for HDD settings in BIOS.And check bios for updates.
War diese Antwort hilfreich?
Bewertung 0
7 Kommentare:
The thing is, since I have Win 10, and the computer won't respond to my efforts, I have no way to access the Bios.
von
Update: Using a Win 10 Repair Disk I burned on my backup laptop, I have gained access to the troubleshooting and repair menu. Will continue to try and fix the problem.
von
why can't you boot into bios? I have 3 computers running W10 and I can get into bios on them all.
von
Update 2: After making a Win 10 repair disk, and doing an "auto repair", Windows has told me that HDD failure is imenent, leading me to believe that the HDD is shot. Will replace with either a hdd/sshd/ Ssd.
von
Can you provide laptop model?
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Imad Knight wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 102
