Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Model A1419 / Ende 2012 / 2,9 und 3,2 GHz Core i5 oder 3,4 GHz Core i7 Processor, ID iMac13,2
309 Fragen Alle anzeigen
4sns 1 c0000008 tl0p 124
Hi I am getting 4sns 1 c0000008 tl0p 124 hard test error. The CPU usage over 400%
Update (08/24/2016)
I have changed the hard drive and bought owc cable + sensor as u adviced
Update (08/24/2016)
ok thanks a lot Mayer jan ( SSD upgrade and kernel_task )
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Kommentare:
Did you change the hard drive?
von
I thought I recognized you. Let's delete this question and go back to the original. There was a months lapse between what I advised and your response and I missed it.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
The problem was with the LCD sensor, no hdd sensor need for kernel_task problem. The HDD sensor is only for fans.
War diese Antwort hilfreich?
Bewertung 0
Is the fan running fast and making very loud. If so, you make to reorient a wire. It is either a heat senser or fan sensor wire.I don't remember the exact name. It has white dot on the conector. You need to turn it 180* from how it was before installed your new hard drive. Infix it has a very good guide that explains it.
Bewertung 0
There is a sensor cable on some iMac models that must be attached to the replacement HDD for the fans to operate normally. I do not recall if the particular models include your mid-2010 iMac but the symptom you describe would be consistent with this requirement.
If you did not buy it from OWC / MacSales or other well-known Apple supporter, it is unlikely to have the required hardware.
Check with OWC to determine the correct replacement you require.
It's an issue in your lower slot
Bewertung 0
Has anybody solved this mysterie ??
I have the same behaviour:
And a kernel tast taking 300% CPU load
Bewertung 0
Kommentare:
You may find using this app will help in locating which sensor is failing: TG Pro See what it shows you.
von
Antwort hinzufügen
Vardan Hovsepyan wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 12
Insgesamt: 1,708
