Zum Hauptinhalt wechseln
Modell A1418 / Ende 2013 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
Can I use this drive in this iMac?
Can I use this drive in my iMac Intel 21.5"EMC 2638?
SSHD-Harddrive 2.5" Bulk Western Digital WD10J31X SATA III
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Spec sheet for the drive: WD Blue PC SSHD (WD10J31X)
von
Thanks Dan for the answer!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There are a few issues here you'll need to consider.
  • The given model you have may require a SATA/power cable harness for the HD/SSHD drive
  • Opening the newer 'Thin Series' iMacs are a bear! And if you are not careful you can damage the display
  • SSHD's can't be used in a Fusion Drive set so if you have an Apple Blade SSD drive you'll need to keep the two drives independent. Also make sure you break the Fusion drive before you take the HD out otherwise you have a very confused system.
  • If you have a Apple Blade SSD you might want to think about just going with a bigger HD like a 1.5 TB or 2 TB SpinPoint HD
OK, you're going for it!
Make sure you have all of the correct tools and fully review this IFIXIT guide here: iMac Intel 21.5" EMC 2638 Hard Drive Replacement.
Now to the drive: Yes! The 2.5" 1 TB WD10J31X will fit and work in your system (review the spec sheet above).
But, are you sure you want to limit the SSD cache to only 8 GB? How about going with a different drive which has a deeper SSD cache (32 GB), it will give you better performance.
I would recommend going with the Seagate 2.5" 1 TB SSHD ST1000LX001
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Anders Berglund wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 100
