Zum Hauptinhalt wechseln
Die 6. Generation der Android-betriebenen Nexusreihe, konzipiert von Google, hergestellt von Huawei. Auf den Markt gekommen im Oktober 2015.
63 Fragen Alle anzeigen
Nexus 6P proximity sensor not working after changing LCD block
Due to water damage I had to replace my LCD block, since then everything works fine but the proximity sensor.
As a result, my screen turns black as soon as I make a phone call and I have no way to terminate the call (I now have enable the `use power button to end call` under the accessibility settings).
With the AndroSensor app, I can see that the proximity sensor reports `0 cm` all the time.
I suppose the issue comes from the repair I made, but I need directions on where exactly to look at inside the phone to diagnose/repair this.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
I have this same problem. I thought the repairman (who I'll still visit to check), had put adhesive glue in between the proximity sensor, but now am starting to think it's definitely a dodgy aftermarket LCD digitizer.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Thomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 553
