Hi,
Check if you have the following setting in your phone. If so enable it. It may not be there. I have 3 different tablets - don't ask - only one has this setting and it is the only one that works with a USB to Ethernet adapter.
Go to Settings > Wireless and Networks > more, tap to enter and see if Ethernet is an option. If so tap to enter and tap on Use Ethernet.
September 1 by jayeff
Hi jayeff,
that is the way how I got the adapter working with my tablet. Unfortunately the Fairphone2 does not offer this setting. Maybe this means that none of such adapters will work. I'll ask the fairphone manufacturer. Thanx!
September 2 by Ralf
Does the fairphone have otg, like does it work with a usb drive or mouse
September 2 by Ethan Chow
Hi Ethan,
Thanx for your answer.
the file manager shows that /storage/usbotg is available, and I tried out and all of the following worked perfectly:
- connection to PC via usbotg
- external hard drive
- external SD card via a universal card reader
- mouse
(besides my question: thanx for giving me the idea to test a mouse at the Fairphone2! I liked it and I'll continue to use a mouse, at least when I'm sitting at my home desk ... )
But still my two USB to Ethernet adapters do not work (Davicom DM9621A, ASIX AX88772B) ...
September 3 by Ralf
Hi @basche_ralf ,
If you're interested, there are some apps available to help you do what you want. Unfortunately they all depend on your phone being rooted. Just "Google" Ethernet to USB android app. Here are just a couple of links.
https://play.google.com/store/apps/detai...
http://forum.xda-developers.com/showthre...
September 4 by jayeff
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Hi,
von jayeff
Hi jayeff,
von Ralf
von echow2001
Hi Ethan,
- mouse
von Ralf
Hi @basche_ralf ,
von jayeff
3 weitere Kommentare anzeigen
