Zum Hauptinhalt wechseln
A sanitary disposal device for human waste. No plumber necessary! Fixing a toilet is more straightforward than many people think.
Consistent dripping sound coming from tank
There is a consistent dripping sound coming from the tank of my toilet. What could it be?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Over time the flapper - which is soft and supple new - becomes dry and hard. Replacing the flapper will normally fix a dripping issue, and it's about a 5 buck repair.
War diese Antwort hilfreich?
Bewertung 3
Hilfreichste Antwort
Flap which stops water to come in side has been wastage.It would be change.
Bewertung 6
1 Kommentar:
Really a score of 8 on this answer! Really amazing and total BS. Having your buddies vote a poor answer up like this risks getting you banned from the site.
@kaykay
von
Here's the guide on replacing the flapper: Toilet Flapper Replacement
Bewertung 5
Try putting a new tank kit in it?
Bewertung 0
1 Kommentar:
It may be time to replace the whole kit soon anyway. As there is no visible water leaking from the tank and no overflows ever, I just wonder what it might be.
von
It' cause of a bad flapper, it can't hold the in the tank and the water is dripping from the tank. You should replace the toilet flapper asap.
Bewertung 0
Antwort hinzufügen
Max Fishman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 17,810
