Zum Hauptinhalt wechseln
A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
starter cord won't retract back
my recoil cord won't retract
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
the pawls are broken. THewy are easy to replace. go to youtube and search "How to replace or repair my tb675ec pawls" https://www.youtube.com/watch?v=V7KduhbV...
bery detailed instruction I did it myself
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@Mike, txhunter2 , it sounds like you both may have a broken recoil. The spring has broken on txhunter2 recoil and on Mike's the flywheel engagement tang's have broken. At the link below I believe the whole recoil assy./housing can be replaced for just over $13.00. Good luck. See below links that may help repair/replace the required part. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.troybilt.com/equipment/ARIPar...
https://www.youtube.com/watch?v=2eSWBmhl...
War diese Antwort hilfreich?
Bewertung 2
Starter cord won't retract
Bewertung 0
Antwort hinzufügen
txhunter2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 33
Insgesamt: 8,167
