Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
Playstation 4 won't turn on after optical drive change
I bought two optical drives for my playstation 4 because the drive won't accept discs due to maybe a bad sensor or damaged mechanisms, I changed the board from the old optical drive to the new ones and installed, but the playstation won't turn on with the new ones, it does turn on with the old one...
Any help is appreciated. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Is the new drive the same model as the original one? Typically with keyed drive replacements, the replacement unit has to be the same model and type as the original, in addition to the drive board replacement.
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
It's a replacement for CUH-1115A, The ones I bought are KEM-490, I'm not sure which laser lens are installed in the original one, but I doubt they have something to do with it...
Apart from the playstation model, where else do I seek for the model and type of the drive? The ones I bought fit in perfectly, but the playstation won't turn on at all with the new ones.
von
Is there a number on the daughter board? There should be one there that says something like BDP-###
von
It says BDP - 015, the new optical drives don't come with daughter boards.
von
From what I'm seeing online, that BDP number on the daughter board is the one to follow looking for a replacement drive. If you can go back to where you bought them, the number could be in the description.
von
Perfect. It was BDP incompatibility. Got a BDP - 010 and worked flawlessly. Many thanks.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
RobertoLL wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 162
