Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
396 Fragen Alle anzeigen
Xbox one S - Loud fan noise
Hi,
I´m recently bought a 2tb Xbox One S and it´s fan sound like something is hitting the blades. Any guess about how to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 10
6 Kommentare
Hi,
I´m glade that my "experience" could help you. It´s really a shame MS quality control.
von
Hey the same is happening to me too, it's past the warranty and I can't return it so which type of fan should I use in replacing it
von
Austin, search for a PWM fan. I used a Corsair one, working better than The original.
There several youtube guides to change The fan, its easy enough to do at home, just take care and not hurry things.
von
Is there a illustration to show one how to perform this fan replacement? , iIfound a Cougar Vortex PWM 800-1500RPM fan
von
I don´t any illustration, but is working fine to me.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Hi Yan,
It´s really simple to change the bearing, you can remove the fan without have to remove the heatsink. The fan is almost the same, but it dont fit well, because the height of the one s. I suggest you change the fan to a custom one, like corsair or another pc fan, it´s really simple, look for guides in Youtube, i got better results changing the fan instead of the bearings.
Hope it could help you.
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
I saw on youtube peoples saying that after changing the fan with an custom one they have problems with overheating. Is that true?
von
I don´t have any problem. It´s important that the fan is a PWM, so it can change the speed of the fan when is necessary.
von
And when you are gaming you are sure that your fan increases speed? And your custom fan is focused for air flow or static pressure?
Thanks!
von
I hear it´s getting faster (and louder), so yes.
von
Thanks for the info! Where did you get the replacement bearings, are they a particular type?
von
2 weitere Kommentare anzeigen
Has anything fallen into the fan? Anything unusual happen to the unit? (Like getting knocked over, hit, etc.) At this point, I would recommend sending it in on warranty. Since it was only just released, you should be able to get it fixed for free under warranty, and you won't risk damaging it more opening it up.
Bewertung 0
Hi Ben Eccles,
I kind of fixed the fan noise. Last night I open the entire console and removed the fan, I discovered that the sound was coming from 2 crap bearing´s inside the fan, changed them and said goodbye for the noise, at least until now.
Tks for the help.
P.S: Sorry about my poor english, I´m from Brasil and I´m a little rusty.
Bewertung 0
1 Kommentar:
No worries! Glad I could help!
von
Hi ricardo
I got the same problem, is it easy to change the bearing? (can i dissemble the fan without removing all the heatsink?)
I was thinking to change the fan myself but i don't know if the Xbox One fan is compatible with the One S fan.
Thx
Bewertung 0
Thx for your help, i have changed the fan, i've used a PWM 120 mm fan.
Now the Xbox is quiet, the hard drive is louder than the fan :)
It's a shame for Microsoft quality control, a lot of people got this problem (and some are thinking the buzzing noise is normal)
Bewertung 0
12 Kommentare:
von
No overheating for me with an Akasa AK-FN064 fan
von
And when you are gaming the fan is increasing the speed?
von
and how did you solve with the conector? what are the pins for controling fan speed?
von
For me it was a little trick, but tested the cable until discover. If you dont set the cable in the right way, it will be set in full speed all the time, even if its on sleep mode.
von
7 weitere Kommentare anzeigen
Hello!
What typ of fans are you guys using? Or rather from what manufacture? Want to be ready to change it if i get the same problem when i recieve my One S.
Bewertung 0
1 Kommentar:
I´m using a PWM fan from corsair. But if you receive yours Xbox One S with the problem, send it back and exchange for a new one.
von
Antwort hinzufügen
ricardogranjaadv wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 10
Letzten 30 Tage: 31
Insgesamt: 34,221
