Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
4079 Fragen Alle anzeigen
Itunes error 4013 after screen and battery change
i've changed a screen and battery on an Iphone 5S, after that it goes directly to "Connect to itunes" on startup screen. I Connect it, get the "update or restore" question and Choose restore, but it wont go on. I've put phone in DFU and get a phone is in recoverymode, start the recovery and it starts the "getting data", then the prepeare phone for update. Screen turns of, apple logo comes on and the the screen turns red or blue (changes from one to the Other if i try several times) and turns of and error 4013 shows up. I've turned antivirus of, firewall of, reinstalled Itunes on computer, checked computer for updates. But it just Returns error 4013.
Any thoughts ? suggestions ??
I've tried With 4 different batterys and 2 different screens, no change.
Ist dies eine gute Frage?
Bewertung 4
Kommentare:
Did you try it without the front camera cable plugged in?
How was the battery removed, was it pryed from the left side of the battery only and not the top or right or bottom side of the battery?
von
Think i've tried With it and without it, but not 100% if i've tried without.
von
Tested With Other screens now, With and without front camera and still the same. It starts to "restore" and the screen turns red og blue and reboots
von
battery was removed With heating up backside, then prying from left side.
von
I have similar problem, just want to add few things i have tried:
1) Took out Screen and connect to itunes - can perform Restore & Update successfully
2) Took out battery and left for a while - Open connection, phone can be used but will have similar problem after restart
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Nand chip must be removed, then formatted with a chip reader, then reinstalled. Jessa just released a video on this issue...
https://www.youtube.com/watch?v=qab9o9pY...
War diese Antwort hilfreich?
Bewertung 1
Hi
Have a look here for a solution
https://support.apple.com/en-gb/HT201444
Thanks
Bewertung 0
Kommentare:
If you've read what i've tried that solution has been tested ofcourse. If it was that easy i would be one happy camper
von
Apple support is a great way to get business for Apple, not to solve your issues.
von
Antwort hinzufügen
thomas wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 17
Insgesamt: 5,539
