Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Veröffentlicht im März 2016. Modell: SM-G930V.
341 Fragen Alle anzeigen
S7 rear camera is not working after screen replacement
Repair was completed by a third party - initial problem was a non-working LCD from a drop; everything else works fine (tested in diagnostics)
Tried every software based solution (e.g. settings reset, reboot, cache deletion).
As tested in diagnostics, front camera works but rear camera says "camera failure".
No physical damage on the camera at all. Would this just be a disconnected cable?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
iPhone LCD Display Fix Kits
Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
Kits kaufen
Reduziere die Reparaturkosten, nicht die Qualität.
Kits kaufen
1 Antwort
Gewählte Lösung
Yes, a loose or partly connected flex could be an issue. This problem should be solved by the third party you mentioned. The fault can only be theirs. No doubt, it's a hardware issue.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
I also have this exact same issue, I will look into getting the repair shop to fix it. Will they have to replace the screen again or is it possible to work on it without repairing it?
Also my recent tabs button is also not working after they "repaired" it. When it was broken the light still came on and now it will not. Is it possible that this is also a hardware issue?
Thanks for any help
von
Antwort hinzufügen
Andy Salad wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 6
Letzten 30 Tage: 24
Insgesamt: 896
