Zum Hauptinhalt wechseln
2012 kündigte Sony Entertainment an, dass die Firma eine neue Version ihrer Playstation 3 Konsole von 2006 herausbringen würde. Die neue Konsole nennt sich Playstation 3 Super Slim und trägt die Modellnummer CECH-4000. Die PlayStation 3 Super Slim (CECH400x) ist die dritte Version der PS3 Video-Spielkonsole, die von Sony Computer Entertainment hergestellt wird. Sie kam am 25. Oktober 2012 auf den Markt.
210 Fragen Alle anzeigen
Can I swap hard drives between a ps3slim and ps3 super slim?
I have a ps3 slim160gb hard drive that's located in the front of the ps3 and I also have a ps3 super slim 500gb hard drive that is located on the side now is it possible to swap hard drives and use one in the other? (example ps3 super slim 500gb hard drive and put it in the ps3 slim) or is there any possible I can retrieve the data that's on the hard drive if the ps3 super slim isn't functional anymore or if you need parts to make it or is there any other possible way I can expand the 160 hard drive to a 500 or can I connect the hard drive to a pc to retrieve the data off of it?????
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It is not possible to retrieve the data if your PS3 does not work. You can dump the data with your original PS3 and some tools, but if you swap the drive, you cannot read any data.
You can use the drive after formatting though.
War diese Antwort hilfreich?
Bewertung 1
Well first of all, yes, but unfortunately you will have to find a way to UPGRADE the system for our PS3 super slim was placed into my Slim PS3 because it was the Slim PS3’s hard drive is burnt out. so you can, but you’ll need a via media internet or something like that to update the system and has to be the update number given (like for example 1.62) or higher.
Bewertung 0
Antwort hinzufügen
Lawrence Boone wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 6,748
