Zum Hauptinhalt wechseln
LTE Version des iPad Mini 2. Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
Sporadic reboting with a blue screen
Greetings!
I have a problematic Mini 2 - it reboots sporadically, flashing blue for a split second.
The problem is the device is actually assembled from a lot of parts of different devices, so I need to know potetial roots of the problem at least.
Say, could it be wrong battery or software problem or what else?
The only thing I found the issue occurs if to use wrong screw to attach the plate covering LCD etc connectors, but its unlikely... (Im pretty sure I didnt)
Please help how to diagnose.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
6 Kommentare
Have to add - the device successfully "survived" several OS reinstalls without a problem.
von
Found that its stable if Wi-Fi is switched off. Just curious if its IC or could be a capacitor etc?
von
So no bluescreens at all with Wi-Fi off?
von
Exactly! At least for 1h30m - I ran a movie on the device successfully! It crashed every 1 - 3 min with Wi-Fi.
von
That really sounds like a software issue. Is it jailbroken? Its not a big deal if it is, just trying to picture the whole situation.
One thing it for sure could be is the wifi antenna is shorted to ground. Its easy to cut that antenna when you are cutting off the tape that holds the LCD in place. Try pulling the wifi antenna and make sure there are not cuts or frays. Hold it up in the air so that none of it touches metal and see if you have the same issue.
My bet is on software but it could be just a bad antenna, which is dirt cheap and easy to fix.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It was cheap battery.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Maaaah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 407
