Zum Hauptinhalt wechseln
Model A1318 / 32 or 64 GB capacity
299 Fragen Alle anzeigen
Broken screen - touch function didn't work before or after repair
Hi,
I'm repairing an iPod 3rd Gen that came to me with a broken screen. The touch aspect didn't work.
After replacing the screen/digitizer, the touch aspect still doesn't work. I've double and triple-checked the cable and am pretty sure I have it in right.
I have also tried hard resetting, restoring, multiple times.
Any help?
Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I just gave up... nothing I could find. I assume the drop damaged the logic board.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If the touch screen doesn't work, then either the digitizer is broken, or the connection is bad, or the logic board is broken.
If you've already tried replacing the digitizer, then disconnect the cable and examine the connector on the logic board with magnification, and see if you see anything you can fix. If not, then you'll have to replace the logic board.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
spacec0w wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,133
