Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
295 Fragen Alle anzeigen
Can't get top right corner screw back in.
I took apart my iphone 4 and, as expected, had trouble removing the top right screw (near the audio jack). Now that I am trying to reassemble, I CAN NOT get the screw back in. I have been working on it for an hour.
I am using the tool kit from ifixit and the screw driver hand is too thick to be able to get a direct line on the screw. I need some advice on how to proceed.
1. Is their a screw driver with a longer thinner shaft that might work?
2. What happens if I leave the screw out altogether? (I did try that but the reassembled phone is unresponsive.
Any other ideas?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi !
As long as this screw is a contact screw, there's no surprise about your phone not responding once reassembled.
I suggest that you use different screwdrivers, not being able to give you an accurate reference as long as I no longer own an iPhone 4. If you still can't manage to screw it or that the head is a bit damaged, some tools sold f.e. at iFixit may help you. I personally use this one for damaged screws.
Screw Extracting Pliers Bild
Produkt
$19.99
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
The screw head is still undamaged. I just can't get the screw driver and driver head alligned.
von
Have you tried with a flat one ?
von
Antwort hinzufügen
A S Koski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 53
