"z" Key not working, Command key also
"z" Key not working at all. Command key will not work with closing programs and closing tabs or dialog windows, But will work copy and paste.
Ist dies eine gute Frage?
2,2 GHz (Turbo Boost bis zu 3,4 GHz), 2,5 GHz (Turbo Boost bis zu 3,7 GHz) oder 2,8 GHz (Turbo Boost bis zu 4,0 GHz) quad-core Intel Core i7 Prozessor mit 6 MB geteiltem L3 Cache.
See if an external USB or Bluetooth keyboard works. If it does go into the Keyboard control panel and click on the 'Input Sources' section. See what your internal keyboard is on the left is it U.S.? If not correct it.
You can also add in a second keyboard and delete the original one then add it back in to refresh it.
You may also want to use the iconic view of the keyboard to double check if the key is working correctly. Under the 'Keyboard' section check off 'Show Keyboard, Emoji & Symbol Viewers in menu bar'. Once you've enabled it go to the upper right of your menu you should see a icon with the command key. Opening the keyboard viewer will allow you to see the pressing of the keys as you type on the keyboard see if the key has failed.
Let us know what you find.
Sadly this is a big job ;-{
You have two ways to do this, either replace the complete upper case while expensive it is by far the least amount of work. Or, take apart the upper case so you can replace the keyboard subassembly. While more complex if you're not careful you can damage the battery in the process.
Here's the IFIXIT guide you'll need to follow for either: MacBook Pro 15" Retina Display Mid 2015 Upper Case Assembly Replacement.
Here is the upper case part: Uppercase w/Battery for Mid '15 MacBook Pro Retina - Apple P/N 661-02536
Here is the keyboard part: Macbook Pro 15" Retina A1398 Keyboard backlight 2012 2013 2014 2015 You do want to get the one with the replacement rivets or screws.
And lastly, if you need a fresh battery: MacBook Pro 15” Retina A1398 Battery.
Here's a vid showing the process of replacing the keyboard: Macbook Pro 15" Retina A1398 Change Keyboard
You might want to see what it will cost you for the Apple Store to repair your system. Sometimes they can do things cheaper and offer a warranty to boot!
Good Luck!
Kommentare:
Nothing seemed to help. I went through your steps and have the virtual keyboard up. So the "z" key does not work at all. The "a" and "q" does not work only when "command" is pressed, but the command works all the time.
von devinyzfr6
OK, you have proved the problem is within the keyboard. Did you spill something into it (drink or water)?
von Dan
Thanks a lot Dan. I have worked on my old mac in the past, much easier. I looked through those steps the other day and thought, oh no! Prob take it to the store and get their outlook. Only a year old.
von devinyzfr6
Knowing when to throw the towel in, letting someone more skilled is smart!
von Dan
Hi devinyzfr6
Know it is a long time at ago but what did you do and did it work. I seem to have the same issue just with other keys.
Mest regards MrT
von Mister T
Letzten 24 Stunden: 7
Letzten 7 Tage: 45
Letzten 30 Tage: 247
Insgesamt: 15,222
