Zum Hauptinhalt wechseln
Ein 10,8" Tablet von Microsoft, erschienen am 5.Mai 2015. Es hat ein Gewicht von 0,622 kg. Der Standfuß kann in drei Positionen festgestellt werden.
LCD Connector is damaged, help!
Hey all,
The connector where the LCD plugs in on my surface 3 was damaged during a screen replacement. The issue is I dont know what the part is called or where to purchase a new one.
Please help me
Update (10/06/2016)
This is the connector in question. This is on the main logic board and the LCD flex plugs into it. The black piece that clamps down on the flex is gone and there is a missing pin.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Is it on the LCD or the logic board?
von
The connector on the board was damaged in case that wasnt clear.
von
[image|907316]
von
Mike check the update. Looks to be a internal 35 pin logic board LCD connector.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Mike, if you can post a picture of damaged connector, it would be a big help to ifixit , I believe the connector is the mother board ribbon connector. Check the attached link and see if it is the motherboard connector, Good luck.
Microsoft Surface 3 Display austauschen
Update (10/06/2016)
Mike, Looks to be a internal 35 pin logic board LCD connector. Hope the link is what you want, you can also try a search yourself for (35 pin lcd connector)
https://www.aliexpress.com/item-img/20-P...
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Posted a picture below showing the connector.
von
Mine too damaged, are you sure it's 35 pin connector at AliExpress
Bewertung 0
I don’t think the above connector from Aliexpress is correct. Looking into it it seems to use the same connector that is on the Samsung Galaxy Note 4 2014. It is actually a 70 pin connector not 35 because there are pins on both sides. You might be able to buy a replacement off eBay or Aliexpress.
Below is the link to the connector on Aliexpress.
FPC Connector From Aliexpress
Bewertung 0
Did anyone ever get anywhere with this??
Bewertung 0
Antwort hinzufügen
Mike Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 2,148
