Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
My dell Tablet is not turning on
well when i go to turn on my dell tablet by android it starts up normally then cuts in and out then goes to a black screen is there any way to restart it or do i have to send it some whare to fix it or is it easy to fix and i can do it myself
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Hi, What happens if you start it with the charger connected and switched on?
von
well when connected to the charger i shows up fine it shows it charging and gaining a charge but when turning it on with the power button it still does the same thing as i posted it will start up fine then flickering like cuting in and out then it just stops showing that it is charging and goes to a black screen with colered lines on the bottem
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It sounds like it is a bad battery that isnt holding a charge. I think it would need to be replaced.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
well maybe but i dont know whare i could buy a battery and for how much and whare can i send it to be replaced or fixed
von
Antwort hinzufügen
Damien Valencia wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 721
