Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
264 Fragen Alle anzeigen
EFI Locked MacBook Pro - Need Help ASAP!
So I Have a Firmware Locked Mid 2012 A1278 MacBook Pro.
I was wondering could I bypass the EFI lock if I buy a new logic board to swap it out.
Help me please! I was ripped off on eBay!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
STOP!
Contact seller & eBay ASAP!
If the system is locked you need to get your money back here. You can't reward theft by sucking it up by buying a new logic board to replace the locked one.
eBay - Law Enforcement Reporting
Depending on how you payed the seller you may be able to stop the payment. If you used a credit card talk with them some offer online purchase protection (i.e. American Express).
eBays numbers:
  • Customer service: 1 (866) 540-3229
  • Technical support: 1 (866) 961-9253
Update (10/08/2016)
Here is the IFIXIT guide you'll need to follow: MacBook Pro 13" Retina Display Late 2012 Logic Board Replacement and here are two possible logic boards:
You may need to replace the SSD as well here. I would get this SSD Enclosure for 2012 & early 2013 MacBook Pro with Retina display and you'll also need to find a friend with a Mac so you can scrub the drive down and prep it up with a clean copy of macOS. If that fails you'll need a new SSD as well.
MacBook Pro 13" Retina (Late 2012) 2.5 GHz Logic Board Bild
Produkt
$299.99
MacBook Pro 13" Retina (Late 2012) 2.9 GHz Logic Board Bild
Produkt
$349.99
War diese Antwort hilfreich?
Bewertung 4
7 Kommentare:
Can't Had It Over 30 Days And No Refunds
Would Replacing The Logic Board Even Work I Don't Want To Waste My Money Please Help
von
Why did you wait so long to turn it on?
It will cost you $800 - 1000 to replace the logic board more than 1/2 again on what you likely paid and more than you would have paid getting a system from a reputable re-seller.
von
Dispute your PayPal payment.
von
LogicBoards For The 2012 Model Run About 300 Bucks Not 800 Thats More Than Unit ItSelf
von
Thanks For The Help I'll Just Replace The LogicBoard
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Producing Maniac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,546
