Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
Phone is stuck on a restart loop after after falling in water
Hi, last night I dropped my iPhone 6 Plus in hot water, I removed the iPhone from the water quickly, dried it with a towel, and it was fine. The first problem I encountered was that it said I had headphones in, but I fixed that with my headphones. My second problem was that my phone charged very slowly overnight, 23% in 6 hours. While getting on my bus, a message reading "Touch ID not accessible" appeared, and my Touch ID stopped working. I switched chargers when I got to school. After that everything seemed fine, I charged my phone when I got to school and it charged normally. Around 2 hours later, after my phone was done charging, my iPhone started the restart loop. I have attempted drying the case and removing it, drying and cleaning around the iPhone and case. What should I do???
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You should have disassembled your phone and clean the internals BEFORE you did all this. Powering up a wet electronic device is never a good idea, now the internals are pretty screwed up and it is going to be a difficult repair.
Try to clean the board carefully using isopropyl alcohol, if any issue persists, this is beyond you, take the phone to a professional and don't expect it to come back fully functional without costing you a fortune.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Any further tips?? I've had my iPhone off since, and will follow through with the solution you suggested when I return him.
von
By now the board must have been extensively corroded. Clean all the corrosion and see if it works, if not, board level repair is required.
von
Antwort hinzufügen
Tommy Waller wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 158
